As an owner of Mytek gear, I’m a bit disappointed in this analogy. Surely an experienced audio >designer sees the difference between an instrument, a source of sound, and reproduction >technology intended to faithfully reproduce a recorded instrument?
This example was meant to show that the concept of “good harmonics” which are all around us in every sound is a part of our natural world, and that the ASR idea that all distortion (which includes these harmonics) are BAD is just a mistaken interpretation of reality. Because this is the foundation of ASR assessments, these assessments are in consequence erroneous. When I say “good distortion” I’m being ridiculed by ASR, which only proves how little understanding of sound science ASR members have.
Anyone who has produced music knows that each piece of equipment starting with microphones has its “sound”, ( meaning distortion) and understanding and managing these “sounds” or “distortion” is part of creative production process that in the end results in a recording that is full of all kinds of distortion. Of course very often, especially with acoustic or orchestral recordings transparency is desirable but it’s usually not accomplished by choosing equipment with the best SINAD but rather, as it’s a very complex process, it usually depends on recording engineer experience. Some of the best acoustic recordings may have been recorded with just two microphones, that happens.
Now, Brooklyn Bridge II include the “normal” (transparent) and “warm” (addtnl 12dB of even harmonics) mode of playback. This is a consumer device, meaning it’s designed to provide a good experience of listening. In our experience most users prefer the “warm” sound, they consider it more “musical”, they simply like it better. Since their satisfaction is the goal, this function makes sense in this case.
However, if a mastering engineer used the same DAC to asses their mastering results, I’d probably discourage them from turning on HAT in this case, as it will skew their mastering result. In other words with HAT on their master may end up sounding thinner than with HAT off. Make sense , right?
From 1990 until 2010 Mytek designed ADCs and DACs exclusively for profesional recording and mastering and we did well.
My design philosophy for these was, during the R&D process is to always A/B compare these two signal paths:
- hi-res source>ADC>DAC>hi-res monitoring system
- hi-res source>wire>hi-res monitoring system
We listen to this, tweak ADC and DAC/ measure too, listen again/ tweak again and so on. Sometime we make circuit changes that don’t show in standard measurements but are audible.
This listening requires a very very hi res monitoring, speakers and amps and headphones like Staxes. The higher resolution of monitors the better you can tell the difference. And there always be some you want to get as close as you can.
Everything has a “sound”. Even a wire has a bit of its own character. Mytek has over the years defined “Mytek Sound” and BBridge has a version of this. When I design a DAC for this sound it’s I’m focusing on transparency, detail and transients, while trying to maintain “musicality” (opposite to clinical/boring which could be a result of approach like Topping). There is usually a sweet spot between the two - "Id make the consumer that probably a bit more musical vs a mastering DAC more precise.
Having said that our consumer DACs are used for mastering, for example Abbey Road has two of the Manhattan DAC IIs and so do severa other mastering studios.
You see, when thinking about “sound quality” you ought to be thinking about the final goal you are trying to accomplish. The goals are different for recording, different for mixing, yet different for mastering and completely different for playback. You ought to use your ears and common sense to get results in all these.
If measurements provided results in a recording studio, everybody would be using these. But none of studio recording sessions starts with measuring the recording chain for minimum distortion. Why? Because it wouldn’t provide the desired result.
Now on my point “Sometime we make circuit changes that don’t show in standard measurements but are audible”. This points to another problem in measurement only approach.
Nothing beats the ears- We can hear things that we cannot measure and this is another problem with Amirs approach. He misses all this that cannot be measured today. Rob Watts of Chord claim that he can hear filter difference down to almost -200dB actually surprisingly is true, but you can’t measure this with AP.
For Amir thing he did not “measure” just do not exists. This approach is equivalent to throwing out scientific data which is a straight road to scientific mistakes or even fraudulent conclusions…
Let’s say Amir measured an FFT of a tape with 60dB DR and saw the noise floor at -60dB. Burried in this noise would be more audio , as much as 40 dB+ down into the noise, yet you would not see this in the standard FFT because it’d be masked by noise. I’m pretty sure that Audio Precision is working on a new generation of intelligent algorithms that will eventually discern the useful signal from “noise” and I’d soon expect a slew of new DSP tools that has a way more sophisticated approach to audio measurements that includes brain science and goes beyond the old SINAD. But until these appear, I’ll reject SINAD as a benchmark for sound quality.
The real audio/sound science is way richer and way more interesting then the boring old simplistic mantra of SINAD at ASR forum. If someone wants audio science, goto aes.org , organization funded in 1948, become a member, start going to conventions, read papers, participate there.
ASR is in comparison an amateur attempt of usurp the sound science authority title by one person who can’t even pass the scientific rigor test. And the worse part is, it is deliberately setup as a hostile place, antithesis of what an open scientific environment needs to be.
