@MiveraAudio you are evil!!!
I meanāt the description
Isnāt it? And MQA decoding at 32/384, WOW!
Hahahahahah! Iām sure everyone went suddenly to check their about pages
We would probably be okay with reading the introduction later
OK release has startedā¦ It takes about 30-40 minutes assuming everything is OKā¦ go get a snack
Updating links, copying builds, iOS/Android stuff, bringing up extra machines to handle load, etcā¦
Iāll probably update mine next week sometime. Iām quite happy with 1.2
Hi All
Got the Email - Roon 1.3 coming today.
Great - but what next?
Do I download the new version from somewhere? Is there an option in Roon to update to latest version? Or does it simply download automatically when I open it and its available?
Fingers crossed it includes support for Tidal MQA Maters decoding and ways to actually search for them.
Bill
When your Roon software has downloaded the new update, it will notify you that an update is available. And regarding MQA, I understand it is coming in a later update.
@danny you should know at least iām in no hurry here Iām just glad you made all the hard work and i have just reinstalled my server and doing lots of fixes with ESXi at the moment and getting my raid card up and running so i can access my music so its all good!
But i have a quick question!
I want to run a dedicated small low resource VM for Roon 1.3 and I was wondering would the Linux be the best way to go? i got another VM with SMB share or NFS or whatever would end up being the best for Roon1.3, I know your busy so all I wish for is a simple yes/no and if no i will contact you in a few days when 1.3 settled.
What a chicken! Actually I might chicken out too and backup tonight. Iād forgotten to backup flushed:
ok, one little issue we had to testā¦ 1.3 is not compatible with 1.2 ā¦ so you have to upgrade everythingā¦we wanted to make sure that if you have the middle setting set (default) of auto-take-minor-and-bugfixes, it wouldnt automatically download/install.
weāve confirmed that, so release is in progress
sorry for the delaysā¦ we are all going nuts like you because we are sooooooooo close
Hi Danny, do you mean 1.2 Remote Apps wonāt work with 1.3 Roon Server? So all Remote Apps need to be upgraded? Cheers mate
The download has begunā¦
Yay! Updating my dbā¦
And itās live!
Lucky! Still no update for me.
Updating database in the DMV.
