Hi, I’m new to Roon, been spending the day trying it out and loving the UI. However theres something wrong with the sound quality. I’m getting a low level electronic noise (I think the best way to describe it is sort of like cicadas or a sort of electronic ringing). This noise is not at a constant level but rather follows the main beat of a song, its especially obvious on EDM.
Checking against the same tracks on Tidal I don’t hear the same noise so this is obviously something being added by Roon.
This has got to be a solution to this as the added noise is something that is obvious, ie something that is not happening to all of the other audiophiles who use it or they wouldn’t!
Roon core is my laptop, USB to Chord Hugo into LCDX’s.
Welcome. Sounds like clipping maybe if it is following along to the beat?
Switch on the clipping indicator to check. It is in Headroom Management in DSP.
Tony’s suggestion wasn’t a solution so much as a diagnostic suggestion. If clipping is indicated, then you need to start changing the headroom to eliminate it.
