Advice on Using Small Green Computer's 300W Linear Power Supply with Nucleus+ (ref#S180BT)
Affected Product
Nucleus
Nucleus Model
Nucleus+ Rev A
I am interested in replacing the stock wall wart power supply of my Nucleus+ with a Linear Power Supply from a company called Small Green Computer. I am considering their 100w 19v Linear Power Supply or their 300w 19v Linear Power Supply. QUESTION: Is there any risk of damage to my Nucleus+ if I use the 300w LPS? Of particular concern is the 10amp output from the 300w LPS. see 300w Linear Power Supply with 4 independent outputs – Small Green Computer
RAM & Internal Storage
1TB Samsung 860 Pro SSD
The Nucleus+ is connected to a Teac NT-505 DAC via a USB cable. The Nucleus+ and DAC are connected to my network via ethernet cable. The DAC is connected to a separate preamp, preamp connected to monoblock amps.
Home Network Details
Home network is typical Cox home network with router which enables internet, cable tv and telephone services.
You should stick with the wall wart that came with the Nucleus. There is no reason whatsoever to replace that.
Unless it died😎
But then I would replace it with another similar priced and spec PS.
No risk of damage whatsoever. SGC are well-versed in these types of things. A quick email with them should quell any further doubts; they are good folks.
