After upgrade to 1.5...networked audio devices are missing [Resolved Mac firewall reset for RAAT]
i just upgraded to 1.5 on a iMAC … after the update only the audio devices (2) that are directly connected to the mac appear as an audio zone … i have 10 other Roon networked audio devices throughout my home (NAD, Roon ready hifiberry audio, denon airplay etc) - my setup has worked fine since its start - what is wrong? dan
Hi @Daniel_Marotta ---- Thank you for the report and sharing your feedback with us. The insight is very appreciated and I am sorry to hear of the troubles.
Moving forward, to help aide in our evaluation of this behavior may I very kindly ask you for the following:
  • An expanded description of your current setup using this link as a guide.
  • Please describe your network configuration/topology, being sure to provide insight into any networking hardware you are currently making use of.
  • Just to verify, you have no firewalls or antivirus applications running anywhere in your setup, correct?
  • While it may seem a touch elementary, since noticing this behavior have you tried rebooting not only the core machine and the endpoints, but also any relevant networking hardware as well?
Lastly, I have enabled diagnostics on your account so our tech team can have a closer look into this behavior. What this action will do is the next time Roon is active on your core a diagnostics report containing a set of your Roon logs will automatically be generated/uploaded directly to our servers.
-Eric
UPDATE: Looks like the report just came in. Passing over to our tech for review.
i have figured out the issue(s) … during the upgrade, the mac firewall reset RAAT “allow”…however, i also need to allow roon and roon.app for the system to work as it did prior to the 1.5 upgrade thanks, dan
