Allo Sparky and USB DAC Issues
I have an Allo Sparky, KALI, Piano DAC 2.1, and decided to attach an USB DAC (Explorer2, Dragonfly red, and iFi DSD nano). All 3 DACs sound like they are playing in slow motion from roon.
The Allo Sparky is running DietPi/roonbridge and the Allo Piano DAC 2.1 works fine, the USB DACs mentioned above is another story.
Any suggestions/configuration changes?
Hi,
we are investigating and will update soon
Update, I setup HQPlayer and that works through Sparky running DietPi and NAA. Roon-HQPlayer (running on my workstation)-Sparky (NAA)-USB attached DAC.
Have an issue with Roon playing through Sparky with an USB attached DAC. The Piano 2.1 DAC works fine.
Hi Govnah,
Could you please replicate the slow playback on USB DAC, then provide us with the following logs?
cat /var/log/RoonBridge_log.txt
cat /var/log/RAATServer_log.txt
dmesg | grep usb
Also, which output frequency/bit-depth is being used on Roon and HQ player?
44.1 16bit 2ch file and I am using a Bryston BDA-3, same behavior as the other USB DACs. Also, don’t have this issue on a RPi 3 w/ the same setup.
root@SparkyAllo:/etc/network# dmesg | grep usb
[ 0.414970] usbcore: registered new interface driver usbfs
[ 0.415047] usbcore: registered new interface driver hub
[ 0.415234] usbcore: registered new device driver usb
[ 0.928326] usbcore: registered new interface driver rtl8150
[ 0.928386] usbcore: registered new interface driver r8152
[ 0.928443] usbcore: registered new interface driver ax88179_178a
[ 0.928497] usbcore: registered new interface driver cdc_ether
[ 0.928551] usbcore: registered new interface driver cdc_subset
[ 0.928649] usbcore: registered new interface driver cdc_ncm
[ 0.928732] usbcore: registered new interface driver asix
[ 0.928793] usbcore: registered new interface driver sr9700_android
[ 0.928863] usbcore: registered new interface driver CoreChips
[ 0.932845] [PowerGate] name: ‘usb3’, on: 1, before SPS_PG_CTL: 0x703360
[ 0.932928] [PowerGate] name: ‘usb3’, on: 1, after SPS_PG_CTL: 0x707760
[ 0.949672] usbcore: registered new interface driver usb-storage
[ 0.949857] usbcore: registered new interface driver usbserial
[ 0.949914] usbcore: registered new interface driver option
[ 0.949963] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.950014] usbcore: registered new interface driver pl2303
[ 0.950068] usbserial: USB Serial support registered for pl2303
[ 0.952731] usbcore: registered new interface driver xpad
[ 0.952812] usbcore: registered new interface driver usb_acecad
[ 0.952874] usbcore: registered new interface driver aiptek
[ 0.952930] usbcore: registered new interface driver gtco
[ 0.952986] usbcore: registered new interface driver hanwang
[ 0.953041] usbcore: registered new interface driver kbtab
[ 0.953096] usbcore: registered new interface driver wacom
[ 0.961874] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 0.961973] usbcore: registered new interface driver rtk_btusb
[ 0.967597] usbcore: registered new interface driver usbhid
[ 0.967611] usbhid: USB HID core driver
[ 1.834164] [atc260x_usb_get_prop] first_power_on = false!
========usb_detect_plugout_event===start det!!========
/imxhdd/opt/1301TAG/sparky_volumio/kernel/drivers/usb/monitor/umonitor_core.c–497, SYS_MSG_USB_B_OUT
[ 1.902799] [PowerGate] name: ‘usb3’, on: 0, before SPS_PG_CTL: 0x717761
[ 1.902817] [PowerGate] name: ‘usb3’, on: 0, after SPS_PG_CTL: 0x717361
/imxhdd/opt/1301TAG/sparky_volumio/kernel/drivers/usb/monitor/umonitor_core.c–746, SYS_MSG_USB_A_IN
[ 2.532192] /imxhdd/opt/1301TAG/sparky_volumio/kernel/drivers/usb/monitor/umonitor_api.c–1212, wake_lock !!!
[ 2.534172] [PowerGate] name: ‘usb3’, on: 1, before SPS_PG_CTL: 0x713361
[ 2.534256] [PowerGate] name: ‘usb3’, on: 1, after SPS_PG_CTL: 0x717761
[ 2.706625] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.706634] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.706642] usb usb1: Product: xHCI Host Controller
[ 2.706648] usb usb1: Manufacturer: Linux 3.10.38 xhci-hcd
[ 2.706653] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 2.893729] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.893741] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.893749] usb usb2: Product: xHCI Host Controller
[ 2.893755] usb usb2: Manufacturer: Linux 3.10.38 xhci-hcd
[ 2.893761] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 3.022243] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 3.046483] usb 1-1: New USB device found, idVendor=1db5, idProduct=0003
[ 3.046530] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 3.046565] usb 1-1: Product: BDA3 Audio 2.0
[ 3.046592] usb 1-1: Manufacturer: Bryston
[ 10.164524] usbcore: registered new interface driver snd-usb-audio
[ 10.932523] [PowerGate] name: ‘usb2_0’, on: 1, before SPS_PG_CTL: 0x717761
[ 10.939250] [PowerGate] name: ‘usb2_0’, on: 1, after SPS_PG_CTL: 0x71ff61
[ 21.482138] [PowerGate] name: ‘usb2_0’, on: 0, before SPS_PG_CTL: 0x71ff61
[ 21.482153] [PowerGate] name: ‘usb2_0’, on: 0, after SPS_PG_CTL: 0x71f761
[ 21.482688] [PowerGate] name: ‘usb2_0’, on: 1, before SPS_PG_CTL: 0x717761
[ 21.482757] [PowerGate] name: ‘usb2_0’, on: 1, after SPS_PG_CTL: 0x71ff61
[ 21.482784] usb reset OK: 0.
[ 21.483588] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 21.483605] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 21.483616] usb usb3: Product: AOTG USB Host Controller Driver
[ 21.483633] usb usb3: Manufacturer: Linux 3.10.38 aotg_hub_hcd
[ 21.483640] usb usb3: SerialNumber: aotg_hcd.0
[ 21.882301] usb 3-1: new high-speed USB device number 2 using aotg_hcd
[ 22.022935] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 22.022965] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 22.022988] usb 3-1: Product: USB 2.0 Hub
RAATServer_log.csv (68.6 KB)
RoonBridge_log.csv (763 Bytes)
What PSU are you using ? How many A on your PSU
Problem was duplicated it on our lab. Seems to be a problem with the USB driver. We are talking to the manufacturer of the CPU to try to fix it asap
Thanks for the reply and will keep an eye out for the fix/driver update.
A fix has been posted Allo sparky and HQPlayer NAA
Please advise if it solves your problems.
Been having some issues installing a new dietpi image as it keeps asking for internet connection even tho the internet test passes and I’m connected in via ssh it’s reporting an issue, so I can’t install the roon bridge files.
Not sure if it’s an issue which the death of AWS causes earlier in the day my time but it’s not happy about something…even tho when I ran dietpi-update it installed stuff from 143 to 144 I think
I also faced this issue today.
I have changed “http://ftp.debian.org/debian” to “http://ftp.debian.org/debian/” on /etc/apt/sources.list then worked
tried the above and I still get
Internet access is required to start the DietPi Installation │
> │ Program. │
> │ Would you like to change your network settings and try again? │
> │ If problems persist: │
> │ Index of /debian may be offline and/or unreachable.
http://dietpi.com/phpbb/viewtopic.php?f=11&t=1373
sorted now I think with that full 4 line replacement…I guess Dan is on top of it too so thats always a good sign :stuck_out_tongue:
Can I ask why you decided to add a USB DAC? I don’t see the point. We all know USB is not good on SBC systems and you have a DAC on your Allo.
