Debian 10 : Roon 521
Classical, ethernet & wifi 5hghz
Honor 8 Android 8
Hi,
Sometimes the connexion to the core with the android remote app is slow (10s)
This is the connexion logs
6:53 Trace: [raat] [sood] Refreshing device list
02/24 23:46:57 Trace: [raat] RAATServer discovered: RaatServer FRD-L09 @ 192.168.1.3:38697
02/24 23:46:57 Info: [raatserver] GOT SERVER 8c06de5c-255c-55cf-2147-b82f16bed26b::8c06de5c255c55cf2147b82f16bed26b @ 192.168.1.3:38697 FRD-L09 PROTOVER=1 RAATVER=1.1.36
02/24 23:46:57 Trace: [raatserver] [RaatServer FRD-L09 @ 192.168.1.3:38697] connecting (attempt 1)
02/24 23:46:58 Trace: [raatserver] [RaatServer FRD-L09 @ 192.168.1.3:38697] connected
02/24 23:46:58 Trace: [rnet/RnetJsonClient] SENT {"request":"enumerate_devices","subscription_id":"0"}
02/24 23:46:58 Trace: [rnet/RnetJsonClient] GOT NONFINAL {"status": "Success", "devices": [{"auto_name": "FRD-L09", "device_id": "default", "auto_enable": true, "type": "android", "name": "Default Output", "is_system_output": true}]}
02/24 23:46:58 Info: [raatserver] GOT DEVICE 8c06de5c255c55cf2147b82f16bed26b::default Type=android Name=Default Output
02/24 23:47:05 Info: [stats] 7469mb Virtual, 1280mb Physical, 588mb Managed, 0 Handles, 96 Threads
02/24 23:47:08 Info: [brokerserver] Client connected: 192.168.1.3:42714
02/24 23:47:08 Trace: [SOOD] Adding User IP 192.168.1.3
Why ten seconds between
and
An other phone (more recent and better CPU)
02/25 00:07:06 Trace: [raat] RAATServer discovered: RaatServer Redmi Note 8 Pro @ 192.168.1.47:38647
02/25 00:07:06 Info: [raatserver] GOT SERVER 2911670e-f8fe-9cfe-4311-a100c896badf::2911670ef8fe9cfe4311a100c896badf @ 192.168.1.47:38647 Redmi Note 8 Pro PROTOVER=1 RAATVER=1.1.36
02/25 00:07:06 Trace: [raatserver] [RaatServer Redmi Note 8 Pro @ 192.168.1.47:38647] connecting (attempt 1)
02/25 00:07:07 Trace: [raatserver] [RaatServer Redmi Note 8 Pro @ 192.168.1.47:38647] connected
02/25 00:07:07 Trace: [rnet/RnetJsonClient] SENT {"request":"enumerate_devices","subscription_id":"0"}
02/25 00:07:09 Trace: [rnet/RnetJsonClient] GOT NONFINAL {"status": "Success", "devices": [{"device_id": "default", "type": "android", "name": "Default Output", "config": {"external_config": {"is_private": true}, "unique_id": "f0aa736b-ceaf-ad13-f8e1-21394cc1b4c4", "volume": {"device": "default", "type": "android"}, "output": {"name": "Default Output", "device": "default", "type": "android"}}, "is_system_output": true, "auto_enable": true, "auto_name": "Redmi Note 8 Pro"}]}
02/25 00:07:09 Info: [raatserver] GOT DEVICE 2911670ef8fe9cfe4311a100c896badf::default Type=android Name=Default Output
02/25 00:07:09 Trace: [rnet/RnetJsonClient] SENT {"request":"enable_device","device_id":"default","subscription_id":"25"}
02/25 00:07:09 Trace: [rnet/RnetJsonClient] GOT NONFINAL {"status": "DeviceChanged", "device": {"device_id": "default", "type": "android", "name": "Default Output", "config": {"external_config": {"is_private": true}, "unique_id": "f0aa736b-ceaf-ad13-f8e1-21394cc1b4c4", "volume": {"device": "default", "type": "android"}, "output": {"name": "Default Output", "device": "default", "type": "android"}}, "discovery_data": {"tcp_port": 39881, "raat_version": "1.1.36", "unique_id": "f0aa736b-ceaf-ad13-f8e1-21394cc1b4c4", "vendor": "N/A", "version": "N/A", "model": "N/A", "protocol_version": "3"}, "is_system_output": true, "auto_enable": true, "auto_name": "Redmi Note 8 Pro"}}
02/25 00:07:09 Info: [raatserver] [Default Output] connecting (attempt 1)
02/25 00:07:09 Trace: [Default Output] [raatclient] Initializing RAAT session
02/25 00:07:09 Trace: [Default Output] [raatclient] Loading script raat.dat:base.lua as module base [1088 chars]
02/25 00:07:09 Trace: [Default Output] [raatclient] Loading script raat.dat:dkjson.lua as module dkjson [22416 chars]
02/25 00:07:09 Trace: [Default Output] [raatclient] Loading script raat.dat:protocol.lua as module protocol [2045 chars]
02/25 00:07:09 Trace: [Default Output] [raatclient] Loading script raat.dat:roon_tcp.lua [43475 chars]
02/25 00:07:09 Trace: [rnet/RnetJsonClient] GOT NONFINAL {"status": "Success"}
02/25 00:07:09 Trace: [Default Output] [raatclient] RAAT Session initialized in 76ms
02/25 00:07:09 Trace: [Default Output] [raatclient] SENT [2]{"request":"info"}
02/25 00:07:09 Trace: [Default Output] [raatclient] SENT [3]{"request":"set_client_type","client_type":"Roon"}
02/25 00:07:09 Trace: [Default Output] [raatclient] GOT [2] {"source_selection":{"info":[],"is_supported":false},"status":"Success","flags":{"has_write_chmap":true},"volume":{"info":{},"is_supported":true},"platform":{"os":"android","uname":{"machine":"aarch64","version":"#1 SMP PREEMPT Tue Dec 10 20:39:11 WIB 2019","nodename":"localhost","release":"4.14.94+","sysname":"Linux"}},"transport":{"info":{"config":{}},"is_update_artwork_supported":true,"is_update_status_supported":true,"is_supported":true},"output":{"info":{"refresh_supported_formats_before_playback":true},"supported_formats":"48000/16/1|2,48000/24/1|2"},"info":{"model":"N/A","raat_version":"1.1.36","protocol_version":"3","unique_id":"f0aa736b-ceaf-ad13-f8e1-21394cc1b4c4","vendor":"N/A","version":"N/A"}}
02/25 00:07:09 Trace: [raatserver] [Default Output] connected
02/25 00:07:09 Info: [transport] creating endpoint for raat device f0aa736b-ceaf-ad13-f8e1-21394cc1b4c4
02/25 00:07:09 Trace: [Default Output] [raatclient] SENT [4]{"request":"subscribe_transport"}
02/25 00:07:09 Trace: [Default Output] [raatclient] SENT [5]{"request":"subscribe_controls","controller_id":"3a509ea7-3831-4d97-9250-bf5680a97d1b"}
02/25 00:07:09 Trace: [dspengine] created new dsp config {"version":3,"items":[{"type":"bs2b","enabled":false},{"type":"parametric_equalizer","enabled":false},{"type":"audeze_presets","enabled":false}]}
02/25 00:07:09 Trace: [transport/audeze] picking preset lowlatency
02/25 00:07:09 Trace: [transport/audeze] picked null preset!
02/25 00:07:09 Trace: [Default Output] [raatclient] GOT [3] {"status":"Success"}
02/25 00:07:09 Trace: [zone Redmi Note 8 Pro] Loading
02/25 00:07:09 Trace: [zone Redmi Note 8 Pro] Suspend
02/25 00:07:09 Trace: [Redmi Note 8 Pro] [zoneplayer/raat] Endpoint Default Output Initial State: Idle
02/25 00:07:09 Info: [transport] created zone Redmi Note 8 Pro
02/25 00:07:09 Info: [transport] with endpoint Default Output (23:1:f0aa736b-ceaf-ad13-f8e1-21394cc1b4c4) [IsAvailable=True]
02/25 00:07:09 Trace: [Redmi Note 8 Pro] [Inactive] [STOPPED @ 0:00]
02/25 00:07:09 Trace: [zone Redmi Note 8 Pro] Loaded Queue=63 Tracks Swim=Inactive AutoSwim=True Loop=Disabled Shuffle=False
02/25 00:07:09 Trace: [Redmi Note 8 Pro] [Inactive] [PAUSED @ 2:11/5:09] Antisocial - Trust
02/25 00:07:09 Trace: [Default Output] [raatclient] GOT [5] {"status":"Success","controls":{"volume":{"min":0.0,"type":"number","step":1.0,"max":15.0,"mute":false,"value":0,"info":{}}},"action":"Changed"}
02/25 00:07:09 Trace: [Default Output] [raatclient] SENT [8]{"request":"update_artwork","mimetype":"image/jpeg"}
02/25 00:07:09 Trace: [Default Output] [raatclient] GOT [8] {"status":"Success"}
02/25 00:07:15 Trace: [broker/accounts] [heartbeat] now=02/24/2020 23:07:15 nextauthrefresh=02/24/2020 23:57:16 nextmachineallocate=02/25/2020 02:57:15
02/25 00:07:17 Info: [brokerserver] Client connected: 192.168.1.47:46152
6s to get ready
To compare, this is my desktop delay (Windows 10) :
02/24 23:52:31 Trace: [raat] RAATServer discovered: RaatServer DESKTOP-FKP2HUH @ 192.168.1.94:62314
02/24 23:52:31 Info: [raatserver] GOT SERVER a2d2d9e3-0f8a-4c25-c724-dcf3026cfab8::58770229-bbb2-433c-98e0-9aeca8470459 @ 192.168.1.94:62314 DESKTOP-FKP2HUH PROTOVER=1 RAATVER=1.1.36
02/24 23:52:31 Trace: [raatserver] [RaatServer DESKTOP-FKP2HUH @ 192.168.1.94:62314] connecting (attempt 1)
02/24 23:52:31 Trace: [raatserver] [RaatServer DESKTOP-FKP2HUH @ 192.168.1.94:62314] connected
02/24 23:52:31 Trace: [rnet/RnetJsonClient] SENT {"request":"enumerate_devices","subscription_id":
Less than 1s…
