I have a NUC 5i running ROCK and the fan seems to be on all the time, yet it seems cold to the touch? Can I check the CPU temperature, say from the command line ROCK leaves you with if you had a monitor attached? Obviously I can reboot into BIOS but Roon isn’t playing then.
