I added 11 albums on Friday morning, nothing showing in my Roon library yet. Although when I go onto the Qobuz page in Roon they’re there. I know things can take a while to sync but a) Tidal is usually the culprit and b) it’s 3 days now, even Tidal would have caught up with itself by now!
Thanks for the suggestion, I hadn’t. So I just have. Still not appearing.
Did you add the albums starting in Roon, or
Did you use the Qobuz app
Or did you use the Qobuz webpage?
Qobuz app …
Then I do not know.
I still ‘benefit’ from the feature that if I heart (favorize) albums at the Qobuz webpage, they become visisble in Toon - Qobuz - My Qobuz -Favorite Albums, but are not added to My (Roon) Library.
When I do it using the Qobuz app, albums are perfectly added to My Library in one go.
I’ve always added albums via Roon and never had a problem
So I went into the Qobuz app again, unfavourited each album, favourited it again, then went to Roon and synced Qobuz. All albums are now in my Roon library. Somewhat annoying, let’s hope it was a one off blip.
