Hi,
Are the correct file links provided with the latest software release message?
Pre-install I get this build/version info:
Hi,
Hi, @ToneDeaf, thank you for flagging. The #401 version of ARC has just been deployed. As for Roon Remote. The version you are getting is the correct one. The last EA release was Desktop-only for Roon.
ā
Ivan
