Applying library settings every 5 minutes
Roon Server Machine
2013 iMac running MacOS 10.15.7
97058 tracks between Qubiz and local libraries.
This has never been an issue in the past and Roon has run great for me but since the last update I get Applying Library Settings every 4 to 5 minutes which runs for about 2 minutes, even when I haven’t made any changes. Roon will display a loading artist or album page. I’m unable to access anything until it’s finished. It’s getting old! Is there anyway of fixing this?
Hi @fireapple,
Thanks for the report - could you please reproduce the issue and send over a set of Roon Server logs? You can use the directions found here and send over a set of logs to our File Uploader.
I’ll be on standby for your reply. Thanks! :+1:
Uploaded today.
Thanks @fireapple,
As a next step, lets refresh your database and restore from a saved backup:
  • Exit out of Roon
  • Find the folder that says “Roon Server”
  • Rename the “Roon Server” folder to “RoonServer_old”
  • Verify if the issue persists on a fresh database before restoring the backup
