I have based my HP audio setup exclusively on Roon/ROCK:
Everything works just fine. Even my VPN connection.
There is just one problem, Roon ARC still uses the standard Android Audio mixer and that is limited to 24/48. If I connect my iBasso DC07 Pro to my FiiO M23 (using USB output) I can fix this problem. But that leaves me with to many devices when “on the road”.
Long time ago - over a year ago - there where talk about that Roon would fix this ARC Android limitation.
If where will be no fix to this limitation, than it would be nice to know. Than I need to replace my DAP with another solution (maybe a DAC/AMP with battery solution in combination with iPhone 15 pro)
It would nice to get a feedback from Roon on this topic.
Thanks and have a nice WE
Torben
