ARC device: iPhone 12 Pro Max, iOS 17.3 beta
Roon server: Build 1358, Intel MacBook Pro, MacOS 14.2.1 beta
When adding new tracks to a playlist which is already available offline the new track will be marked as downloaded but is in fact not.
As you can see above, the track “Kingdom” is marked as downloaded.
But once I turn on offline mode it’s labeled as unavailable while still marked as downloaded. If I try to play the track without going offline and the Roon server isn’t reachable it will try to load it before it eventually moves on to the next track.
As there’s nothing I can do to force download it without removing the whole playlist from my downloads I have to create a new playlist and make that available offline. For some reason I have to add another track for the download option to be visible.
When connected to WiFi the downloads button/icon in the upper right corner is purple although there are no downloads in progress.
