Roon Server Machine
Mac mini M1 8G Sequoia 15.0
Starlink in bridge mode, google mesh with upnp enabled. Roon server has same IP as Mac mini which is configured to use reserved IP.
Who is your internet service provider?
Starlink -
Please list the make and model of your modem and router?
Google mesh -
Do you have any additional network hardware, like additional routers or managed switches?
Standard switch between main google mesh box and Mac mini. Mac mini wired into switch. -
Does your network have any VPNs, proxy servers, or enterprise-grade security?
No
Description of Issue -
What is the exact port forwarding error message you see in the Roon Settings → ARC tab?
Used to be able to connect to ARC (albeit unusable outside of house) but never really used ARC due to instability. Recently upgraded Roon server and now completely unable to connect to ARC.
Went through all trouble shooting docs as of done multiple times in the past getting it to work first time round. No joy this time though, tried upnp toggling, tried manual port forwarding, nothing works now.
“ipv4_connectivity”: {“status”:“NetworkError”,“status_code”:504,“error”:“error: Error: ETIMEDOUT, response code: undefined, body: undefined connected? undefined”},
“external_ip”: {“actual_external_ip”:“145.ggg.hhh.iii”,“actual_external_ipv6”:“null”,“router_external_ip”:“null”},
“upnp_autoconfig”: {“status”:“NotFound”}
