ARC Connectivity Issue with Deco XE75 Mesh Router (ref#M4QWRR)
I am able to connect ARC to the Roon server and cloud but only if I take Roon Core off the “Client List to use VPN function” of my Deco XE75 mesh router. Is this a safe way to configure ARC? Thank you.
Deco XE75 mesh router using NordVPN. ROCK is hard wired to a network switch.
Have a read here (then head over to tinkering and search for help with your question):
Hi @Calvin_Blasco,
Roon does not officially support using VPNs with the Roon server. However other users in tinkering may be able to help you make this work. I’ll move this post to that category for you.
Thank you.
