ARC crashes on iPhone 12 Pro Max
New version of ARC 1.67.360 crashes on iPhone 13 Pro Max after 1-2 minutes of playing.
Reboot the phone.
Rebooted, deleted and reinstalled from scratch. Does not work.
On Home Screen has issue - do not display Recently added and recently played.
Too bad I let it update today…
Same her with iPhone 14 and iOS 18.5 after yesterday’s update.
App crashes after +/- 1min of playback. It does on wifi or cellular; and with downloaded, library, or Tidal content.
I have restarted the phone several times and still crashes.
I don’t want to reinstall as I would lose +75gb of downloaded content (it would be the “nth” time I’d have to do it in Arc :angry:)
Added support link for follow up.
Hi @Sergei_Sokolov,
This thread indicates you might require assistance from Roon technical support.
Respond to the prompts there to ensure that you’ve performed basic troubleshooting and to ensure Technical Support has the full details necessary to expedite Technical Support’s investigation into the case.
Your responses will auto-generate a Community thread in the appropriate section.
