Roon Server Machine
Microsoft Windows 11 Pro, 10.0.22621 N/A Build 22621
Intel64 Family 6 Model 142 Stepping 10
Total Physical Memory: 32,637 MB
Wifi: Netgear Deco M9 Plus
700,000 digitally
ARC mystery: iPad M1 Pro connects, iPhone 15 Pro Max does not connect, same iPhone 15 Pro Max Roon app works just fine.
Context: This is all on my home Wifi network. I have rebooted the router, rebooted the Roon server, and rebooted my iPhone.
Roon works fine on my iPhone 15 Pro Max:
Roon Arc works on my iPad Pro M1 1TB, with the exception of frequent amnesia ‘synching for the first time’:
Roon Arc does not work at all on my iPhone 15 Pro Max 1TB:
All versions of Roon on PC, Mac, iPad claim in settings that ARC is ready. Also, this is inside the firewall. For good measure, I have also added port forwarding on the firewall. I have turned off cellular on the iPad and iPhone to avoid network routing confusion. I have turned off Windows Firewall on the Roon Server completely.
At this point, I’m stuck. I would love to enjoy ARC on my iPhone.
Any suggestions?
