So I recently bought a 200 dollar Chinese android cellphone that has very slow performance. So much so that i am returning it.
The Roon remote app though has FASTER and more robust performance on the Chinese phone than on my iphone 15 pro that has 1 tb of space !!!
How on earth can this be??? Everything else on my iphone is very very fast.
Hi @davidh,
We’ll need a little more information to take action on this support thread.
Are you encountering slow performance with browsing in ARC, or are you encountering playback problems? Do these symptoms occur on the iPhone while you are connected via cellular data or via WiFi?
What apps are open in the background when the symptoms occur?
Most importantly, are you playing to an endpoint (USB-C or Bluetooth) or the phone’s system output?
