ARC poor connection in WiFi and cellular
Roon nucleus iPhone 11
Links’s
Roon arc worked when initially set up but now I get a constant poor connection message and can’t use it all. I’ve rebooted, reset, etc to no avail
Need help
Please do answer the questions from the template and provide all details about your setup. Otherwise, everyone will just be guessing
Hi @kerry_harvey,
I see you reported an issue. Are you still having trouble?
If so, will you please complete the template below and share a screenshot or copy of what you see when you go to Settings>Roon ARC in Roon?
Are you having issues with streaming Tidal, Qobuz, local files, or a combination of the three?
If everything is working great, we’d like to hear that too!
Thanks,
Wes
Include your operating system and machine info (Model, CPU, RAM).
Your networking gear (model of routers/switches/etc), connection types (Wifi/Ethernet), and any firewalls, antivirus, or VPN software.
Specify what devices you’re using and their connection types, like USB/HDMI/Chromecast, etc.
Tell us how large your music library is, eg. “30,000 tracks”.
Tell us about the problem you’re having in as much detail as possible. Screenshots are always appreciated!
