Hi together.
Some issues with Roon ARC from Germany…
You will find below my spezifications.
Roon Core 2.0, build 1234 running on Synology DS1522+ (AMD Ryzon 1600, 8GB Ram)
The NAS with the runnunig Core ist directly attached to the FritzBox
Who is your internet service provider?
1und1 Germany -
Please list the make and model of your modem and router?
FritzBox 7590, Newest Firmware (7.50), UpnP aktive, Portforwarding for Roon and NAS set and aktiv. -
Do you have any additional network hardware, like additional routers or managed switches?
No -
Does your network have any VPNs, proxy servers, or enterprise-grade security?
No
I cannot connet with Roon ARC from outside of my home.
Here are the error-informations from the connection test. Please note that I masked the IP-address with x’s.
“ipv6_connectivity”: {“status”:“NetworkError”,“status_code”:502,“error”:“error: Error: connect ECONNREFUSED 2001:xxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxxx, response code: undefined, body: undefined”},
“ipv4_connectivity”: {“status”:“NetworkError”,“status_code”:504,“error”:“error: Error: ETIMEDOUT, response code: undefined, body: undefined connected? undefined”},
“external_ip”: {“actual_external_ip”:“89.hhh.iii.ppp”,“actual_external_ipv6”:“2001:aaa:bbb:ooo:ddd:eee:fff:ggg”,“router_external_ip”:“null”},
“status”: “status”: MultipleNatFound
“upnp_autoconfig”: {“server_ip”:“19x.xxx.xxx.1”,“found_upnp”:true}
Unfortunally, I have no idea, how to fix the problem. Could it be a non-static-IP-address problem? How to solve this, if I cant get a static IP-address from my provider?
Perhabs someone can helb me. Many thanks in advance.
