Roon Server Machine
Laptop - KF7TQ3SL Intel core i3 8145 u cpu @2.1 ghz - 2.3 ghz
8 GB 64X64 processor
Windows 11
Telenor Router 2 only Wifi no VPN
KEF LS 50 W (1 gen)
LG G1 TV
Apple TV 4K
From TV to Kef with optical
From Apple TV with HDMI to TV
8400 Tracks
It starts with this when trying ARC.
"ipv6_connectivity": {"status":"NetworkError","status_code":504,"error":"error: Error: ETIMEDOUT, response code: undefined, body: undefined connected? undefined"},
"ipv4_connectivity": {"status":"NetworkError","status_code":504,"error":"error: Error: ETIMEDOUT, response code: undefined, body: undefined connected? undefined"},
"external_ip": {"actual_external_ip":"80.hhh.iii.jjj","actual_external_ipv6":"2001:aaa:bbb:ccc:ddd:eee:fff:ggg","router_external_ip":"null"},
"natpmp_autoconfig": {"status":"NotFound"},
"upnp_autoconfig": {"server_ip":"10.0.0.138","found_upnp":true,"error":"<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n<s:Fault>\n<faultcode>s:Client</faultcode>\n<faultstring>UPnPError</faultstring>\n<detail>\n<UPnPError xmlns=\"urn:schemas-upnp-org:control-1-0\">\n<errorCode>718</errorCode>\n<errorDescription>ConflictInMappingEntry</errorDescription>\n</UPnPError>\n</detail>\n</s:Fault>\n</s:Body>\n</s:Envelope>\n"}
Roon remote will not work!
No sound in my speaker only inside the pc!
They will not change from 2.4ghz to 5 ghz if that is really important. Looses contact with Roon after 10/20 sek. Roon finds them and when I hit play it shows that it plays inthe software, but no sound. Tried every remote i have with volume.
I am not a technician and this is the first time trying Roon which has become a pain! Downloaded it 2 days ago!
My iPhone 14 pro as remote will not work. `Waiting for your Roon server… is what I get on my phone-
On my phone Roon ARC says `to connect please check if core is configuered for remote access. Pressed yes in the column in the software.
I think my three end points running on the same IP address. Phone, PC and KEF.
IPv6 and IPv4 it says on the router that it is using both. Can not turn off IPv6!
When turning firewall off, the remote suddenly works untill I start the firewall again. But the ARC doesn`t do anything. There is something with the firewall!
Can someone please help!
Anders
