After switching to a new Mac Mini, now an M1 that runs on Ventrua OS, Roon does not recognizes the Asio Device only sees the Core Audio. Dac is ExaSound e62, which operates on both Asio and Core Audio. Anyone with same issue?
FWIW, I have a MAC Mini M1 2020 and it runs my Roon Core splendidly…my Roon Server, where my Library is stored, plays from there is run on my 2012 Mac Mini. I did this because my 2012 Mini runs on 12VDC ands is dead quite with no AC noise on the line.
Only roon, other app do work ok?
Can you select from system prefs the asio exa as default and then run roon on default? Just an idea, hope that an exa user will know more
Roon sees the Exasound as 2 different devices, one Asio and one Core. It used to work perfectly with my previous Mac Mini, however when I moved to the M1 Roon stoped seeing the Asio Device. I’m am guessing it’s an issue between the Exasound drivers and the new OS, Ventura, because it is the only real difference between the current setup and the previous one I. The old Mac. But not 100% sure.
