Hello! I'm afraid that I don't have the knowledge or authority to upload to the OPRA Project for use with MUSE but hope that someone can.
I think that the info.json file to be uploaded under the Sennheiser HD 6xx might look as I've entered below. I'm basing what I've typed on what's shown at the specified link, so hope that I've interpreted correctly. Someone might want to search for "HD 650" (currently item 15/298) on that page to find the relevant information to verify my work. I'm particularly not sure about the first parameter in the list shown for "gain_db", for which I entered -11.5, nor if the order of the "bands" entries matters.
"name": "headphones.com EQ Repository HD 650",
"author": "listener",
"link": "https://forum.headphones.com/t/headphones-com-eq-repository-request-thread/23552/15",
"blurb": "HD 650 EQ used as proxy for HD 6xx, which has similar sound signature",
"type": "parametric_eq",
"parameters": {
"gain_db": -11.5,
"bands": [
{ "type": "peak_dip", "frequency": 20, "gain_db": 5.7, "q": 1.0 },
{ "type": "low_shelf", "frequency": 80, "gain_db": 2.0, "q": 0.7 },
{ "type": "low_shelf", "frequency": 110, "gain_db": 4.0, "q": 0.7 },
{ "type": "peak_dip", "frequency": 120, "gain_db": -2.3, "q": 0.6 },
{ "type": "peak_dip", "frequency": 240, "gain_db": -0.9, "q": 0.7 },
{ "type": "peak_dip", "frequency": 615, "gain_db": 0.5, "q": 1.4 },
{ "type": "peak_dip", "frequency": 1350, "gain_db": -0.7, "q": 1.8 },
{ "type": "peak_dip", "frequency": 2150, "gain_db": 0.8, "q": 1.5 },
{ "type": "peak_dip", "frequency": 3333, "gain_db": -1.5, "q": 2.0 },
{ "type": "high_shelf", "frequency": 4000, "gain_db": 0.0, "q": 0.7 }
N/A
