The length of time it takes depends on your library size, the size of the files, and Core machine performance. If you go to Settings > Library does it show how far along analysis is?
As you can see there are 6 cds in the collection but only 5 show up in Roon
The point about the clicks is that it used to be worse than it is now
There occasionally can be one click between tracks - only if I move a track on and very rarely. It used to be more often and so I altered the audio analysis speed and I guess I was asking a question - would this have made the difference re the clicking?
Possibly. Changing it to fast could have sped up the process (which can be a bit more resource-intensive than usual) so that those resources weren’t being used as long and then once complete caused less issues.
To clarify, though, it looks like you’re having an issue with importing, not audio analysis.
If you go to Settings > Library > Skipped Files do you see any of your missing files there?
I’d like to recommend looking at a couple of specific examples of tracks that did not get imported into Roon. Are they supported files? Are they showing up in Skipped Files? If it looks like they should be importing, let me know! Screenshots of these files in their storage location would be helpful for discovering what may be happening.
There is only one case of that I am aware of where a folder with files in not being imported - that is the one already shown of the Tchaikovsky Ballets
CD 5 is in my database along with cds 1 - 4 and 6 i.e.
Okay, first, can you check to see if you can find these files when you filter by path? It’s possible that they are being imported but not identified correctly, so this will help us determine if this is the case or if it’s not importing at all.
So first you’ll need to enable the Path option which you can do by changing the toggle so that it’s blue. After this, Path will show up as a column on this page. You can then filter that column as you would any other column.
There are a couple ways to do this. The album is in Roon but appears to not be showing correctly. If you navigate to the album by clicking the link on the tracks browser you can add it to a Tag. You can then add the album with the other discs to the same Tag. Open that Tag and then you can select them both and merge them.
