Is there any change in behavior if you reboot your Core? I’ve enabled diagnostics mode and what this action does is automatically upload a log set to our servers. I see that these were the last few files Roon was trying to analyze.
D:\MP3\Beto Vazquez Infinity\2006 - Flying Towards the New Horizon\02 - After the Tempest.mp3
D:\MP3\Beto Vazquez Infinity\2006 - Flying Towards the New Horizon\05 - Time of Reflection.mp3
Can you please try moving these .mp3 files out of your watched storage location and reboot the Core? Does the issue then stop?
Note, please do not delete the files just yet, because if they are indeed the ones causing the issue I would like to kindly request them for QA purposes.
Hi @noris it worked, I moved those files to another folder, restarted the Core and it was fixed. Then moved the files BACK to the original forlder, restarted the Core and the Analysis got stuck like before.
Let me know how can I send you the files if you need them.
Thanks again.
Thanks for letting me know these are the offending files. Can you please upload them to Dropbox / Google Drive / Send.firefox.com and private message me a link (click my name -> message)?
