Stand alone core on iMac.
Chord Hugo1 DAC.
DAC which prior to Roon installation showed under Audio outputs in Sound Preferences and fed a BandO system. The only sound outputs shown are now the internal iMac and a networked Roon Ready NAIM MuSoQB 2nd generation. In SetUp settings Audio only the MuSo shows up. On the iMac Sound preferences the Hugo no longer shows. Any suggestion welcomed.
Hello @James_Brinsford, and thanks for reporting this! How is the Hugo connected to the core? Can you elaborate on your network setup? Have you rebooted since this issue started?
Determined that my Hugo is at fault, continuous flashing lamp on volume control. Have replaced temporarily pending repair by Dragongly Cobalt which after setup has resolved my difficulty. It was unfortunate the failure was during ROON set up. Thank you for your response. James
