I’ve had the same problem since installing the HTPC with Roon Bridge.
The System Output on the PC is disable after a reboot.
Hi Michael, each support request should be in their own thread. I moved your post to a new thread so that support will see and engage.
Hello @Michael_Schmitt, have you reinstalled drivers for this device using the manufacturer’s recommendation on tried reinstalling Roon Bridge?
Hello Nuwriy,
look here, sorry.
