· My DAC, streamer, or speaker doesn't appear as a Zone in Roon
· WiFi
· RoonReady
· No, it does not show up there
Since you are using a network connection to the device, please ensure that your RoonServer is on the same subnet as the device
· My devices are on a single subnet but is not visible to Roon
· I have a *mesh network* with devices connected to multiples points
Your local network might need some re-arranging to support Roon.
· None of the suggestions have helped me. I'd like to submit a support request.
· Diverse iPads ,iPhones and Fiio m11 Pro
Not able to Play ROON on iPad,iPhone or Fiio M11 Pro,These are Not visible in Audio,all other devices
work properly
Apple mini,Netgear
