Roon version: 1.3 (build 216) 64 bit
OS: Windows 10, Version 1703, Build 15063.138
PC spec: i7 6850k, 32gb ddr4, gtx 1080,
Library location: internal WD Red 4tb hdd
specs cont. - https://pcpartpicker.com/user/Rumiho/saved/XvZwP6
Library size: approximately 30k tracks
DAC - Chord Mojo, latest drivers from Chord
When opening roon audio devices all show as disabled.
If the enable button is clicked roon will endlessly try to load the device.
Clicking anywhere stops the loading but the above repeats if enable is clicked again.
uninstall / re-install roon --> loading a backup (multiple tested)
uninstall / re-install roon --> clean set-up (re-logging, etc.)
uninstall / re-install graphics drivers
uninstall all audio drivers and re-install most recent versions
tested dac with each usb port available
The weirdest part is that Roon was working perfectly for a few hours this morning then after closing/re-opening the issue started. The only update/change I can find that happened during that time was a Windows 10 cumulative update (KB4015583) which appears to mainly be just security updates.
Just ran a system restore from a day ago (closest I had) when I know it was working and the issue unfortunately persists so it would appear to not be related to the that W10 cumulative update.
Hi @Rumiho ----- Thank you for the report and my apologies for the troubles here. Can you dump me a set of your logs via a dropbox download link in a PM and we’ll have a look to see if we can identify the problem here?
Hi @Rumiho ---- Thank you for the PM, confirming that your logs have been received and are in our queue to be evaluated. Once I have some feedback I will be sure to touch base with you asap.
Great, thanks. In addition, I just observed an alternate behavior when trying to enable an audio device again. The devices were visible but completely disappeared once enable was clicked (re-appeared on re-launch but still unavailable). If I click refresh it loads continuously in the same way “loading” does when the devices are visible.
I believe I was able to fix (?), at least for now, the issue with audio devices not being available by doing the following:
uninstall / install fresh Roon installation
uninstalling / disabling all audio devices Roon could see and opening Roon
closing Roon and installing / re-enabling all audio devices.
after re-opening Roon here, audio devices were configurable and appeared to be working.
I had another error right after where audio playback would fail instantly when attempted and cycle through remaining songs.
That issue was fixed after a restart and everything appears to be working currently so I’ll mark this topic as resolved. I think that I’ll be trying at some point to set-up a linux Roon core though to not have deal with Windows for this at least.
