Just this week my output zone images are missing for a couple of devices.
Also a reoccurring issue is album images from Tidal don’t show. I have to close the Roon app on iPad to see them again. Buggy??
Thanks for reaching out, @Paula_Dickerson!
Since noticing this behavior have you tried rebooting your Core machine and endpoints?
Does this behavior only occur on the iPad, or do you see it on other remotes as well?
If you reinstall the application on the iPad is there any change?
Thanks,
Dylan
The problem occurs of all iOS devices.
I have had to reinstall Roon several times over the last 6 months. I’ll try the reinstall again to see if it fixes the problem.
After the update today which I guess reinstalled the iPad app the audio output images are showing again.
I’m glad to hear that, @Paula_Dickerson!
If you see this issue return please let me know and we can take a closer look here.
Thanks,
Dylan
