I had a problem with my remote entry on my laptop, somehow there was a cofusionn with my microsoft account.
After I solved this problem all of a suddend Roon could not find any audio device , the setting page audio is completly empty. Then I rebooted all devices now Ican not enter Roon any more, the page shows the roon logo but not more ???
What can I do ?
Thanks for advice but unfortunately after rebooting everything Roon can not find my Core at all
Even not with the ip
So what to do?
Thanks for help
Hello in the mean time I deleted Tidal, now the system is working again.
Please let me know when I can reinstall Tidal again.
Try this
Hi @Jurgen_Thiele, you should be able to sign back in to Tidal and have things work. Let me know if you see differently, though!
