MacPro 2012 / MacOS High Sierra v10.13.6 / Roon v 1.6 (build 416)
WiFi / Netgear / model CM450-1 TLAUS
I want to use the system output of the MacPro on which I have installed Roon and its core. Its core is located on a USB connected external hard drive comprising roughly 3.25TB of music.
When I go to the audio tab it is blank, even for the operating system. The only message is “Networked - these devices have been located on your network” and below that is nothing; no options at all, even for the “system output” - no matter how many times I have logged out, shut down, and restarted. I have read the FAQ: Audio Basics and Audio Setup Basics in the Knowledge base, but it does not provide the fix. Can you help?
