Audio zone help - Bowers and Wilkins Zeppelin
Hi,
I’m completely new to Roon and giving it trial on my Bowers and Wilkins Zeppelin while I’m waiting for my Formation Duos to arrive. Streaming through Tidal.
Yesterday I had the Zeppelin connected and showing up in the core audio of the audio zone as well as the AirPlay. Today it is only appearing in the other network devised (AirPlay). See pic of today’s screen. I’m unable to work out how to get it to appear in the coreaudio again. If anybody can help.
Thanks Lewis
Try rebooting everything
No good. Re-booted WiFi also.
Hello @Lewis_Sheppard,
Thanks so much for getting in touch and sorry about the trouble :sweat:
I was wondering if you could check that your Zeppelin is running the latest firmware update.
Did you ever connect it via a wired connection?
Thanks :pray:
Did you rename it to “krk”?
