Just got this message from B&W support. They’re blaming ROON now. I believe B&W just isn’t able to fix this. Guess we’ll all be needing to have to deal with this issue never being fixed.
Dear Mr. Detmers,
Thank you for your patience while we continue to investigate the Roon Ready issue affecting your Formation devices.
Following a further internal review, our team suggests that the problem may be related to how the latest Roon update is being interpreted by the Formation devices.
To help us investigate this further, we would kindly recommend contacting Roon Support, if you have not already done so, and sharing the diagnostic information you provided to us, including the fact that the issue started immediately after the Formation firmware update to version 2.10A1. Any findings or recommendations from Roon Support would be helpful for our ongoing investigation and could help both teams identify the cause of the issue.
We understand how frustrating this situation is, especially given that Roon Ready functionality worked correctly before the update. We are sorry for the inconvenience this has caused. Unfortunately, we do not yet have a confirmed solution or estimated resolution time, but we will continue to follow up on your case.
Thank you again for your cooperation and understanding.
I have a different reply from B&W (received last week)
Hello Paul,
Regarding the roon issue with your Formation duo speakers;
I have some additional q and a regarding the matter, as this is a known issue the team shared these informations with us.
What caused it?
Formation products use specific credentials to connect to Roon. After software version 2.10, this credential stopped working with Roon, so connection to the speakers may be briefly established but can’t finish.
That’s why they’ve dropped out of Roon Ready but still work over AirPlay.
What are we doing about it?
We’ve worked with Roon on a fix that updates this credential. In our testing it restored Roon Ready connectivity on Formation speakers, and they played music normally. The fix is now in final testing.
When will it be fixed?
The fix will come in an upcoming Formation software update, which your speakers will install automatically. We can’t give you a firm date yet, but we’ll contact you as soon as it’s available.
Why can’t the update be rolled back?
Instead of going back to the older software, we’re releasing a corrected update so you get the Roon fix along with the other improvements in recent versions.
Until then, you can keep playing music from Roon to your Formation Duo using AirPlay.
Thank you for your patience, and sorry again for the trouble.
Should there be any questions or suggestions, please do not hesitate to ask, we are eager to help you!
That is a much better update, thank for sharing Paul.
Also, it occurred to me that B&W and Roon are both Harman companies so there can only be so much finger pointing if the update Solko posted proves to be more accurate.
Really that’s it? Having been in IT I have had my share of credential related issues. Usually that boils down to a couple of solutions. Fix the current credentials or create new ones. Either are usually fixable in minutes. And all it would have taken is a quick firmware update on B&W’s side or a quick software update on ROON’s side. I guess the developers are speaking different languages or are for some other reason not able to come to a pragmatic, working solution in a fashion that would actually have their customers feel like they are taken seriously.
It’s been over a month(!) and now this is the update we receive? I am flabbergasted. I just can’t find the word to express how stupid this all is
Alas … hopefully someone will find the right AI prompt to fix the code causing this issue.
I am just as annoyed. It is their product that’s not working because of their update, so much is clear. It takes some time to fill in the form on their website and contact them, however I think the more of us contact them, hopefully the more priority B&W will give to the solution. So I hope - just like you - more of us will do this. Keeping my fingers crossed this firmware update will roll out quickly.
I asked for my case that I opened last week to be escalated. I pointed them to this thread and noted that they are telling people different things about what is going on.
I think this is striking and yet telling at the same time. What makes them fine people at B&W think we are waiting for other ‘improvements’ and marking that as a reason not to go back to the older software?
We need a fix for our ROON Ready devices which obviously have not been so very ready as of late. Can’t you fix the other ‘improvements’ at some other time in the near (or rather distant after fixing its ROON Readiness) future?
Come to think of it, while you are thinking improvements, how about you improve by giving people the option to opt-out if they feel perfectly fine with what they have? The idea of you being able to update my property at will sounds quite frightful, especially knowing now that you could lose basic functionality because of human error.
Alas enough for now… waiting impatiently for your fix… whatever that may be… fixing the credentials in an attempt to restore faith would be highly appreciated …
· My B&W Formation Duo speakers is not longer visible under Roon Ready section in Settings. I Can not select them (just via ariplay) B&W fimrware/software is up to date - also my Nucleaus+ and Roon software are the latest.
It is deeply disappointing that, nearly a month later, the root cause of the issue has yet to be identified. Even if the problem originated from the B&W firmware, the fact remains that the “Roon Ready” connection is failing; therefore, Roon should be actively collaborating with B&W—while also conducting its own internal diagnostics—to pinpoint the cause and find a solution. Based on information shared by others, it seems as though each company is shifting the blame onto the other, and even their respective support staff offer conflicting explanations for the issue—it is, quite frankly, a complete mess. I am becoming increasingly frustrated that I am unable to use Roon properly, despite paying a subscription fee that is far from inexpensive.
I have written the President of Sound United / Harman requesting assistance.
Hi Lyle,
I am a long-time Bowers & Wilkins customer writing to request your help escalating a critical open technical issue that has broken Roon integration across the entire B&W Formation product line. This issue was discovered, and B&W support was first made aware on September 24.
A B&W issued firmware update (2.10) caused ALL Formation products to lose their Roon Ready capability. My setup—including Formation Duos, Formation Bass, a Formation Soundbar, and a Formation Audio—is completely impacted, as are systems for users across the entire Formation ecosystem.
After nearly six weeks, B&W support has provided no meaningful progress or clear guidance. Customers are receiving conflicting updates, ranging from claims that the issue is still under investigation to statements that a fix is currently being tested (weeks ago) or even total non-awareness of the problem. Crucially, this firmware update is still actively propagating, taking down additional working customer systems daily. Even more frsutrating is that technical end customers, have already diagnosed the problem as a credential issue that would seem to be staightforward to resolve considering both B&W as well as Roon are Harman companies.
Given the nature of the Formation line and the length of this outage, the user community seeks your executive visibility to prioritize a resolution and pause the rollout of the broken update. Your assistance in escalating this to the software engineering team or whoever is relevant for an official update would be greatly appreciated and would also help restore some lost faith in Bowers and Wilkins.
My ticket related to this issue is 261029-000650. Additionally, there are many frustrated users communicating openly about this issue on community.roonlabs.com.
