Hello Roon.
After updating on the tablet Huawei MediaPad T3 10. 5,1,3. Room Remote 2.0-1149, the App time to time freezes when trying to view overview of some artists. Restarting of the tablet, app and Necleus+ does not help. Repaired only by deleting and reinstalling the Roon Remote.
Best regards
Yury
Check if you have Wikipedia set as your default (top) option under Settings → General → Editorial Sources
Happening on all my Android devices.
I have disabled Wikipedia on my Androids. Problem solved
Thank you. Disabled while working.
Are you running Early Access builds? If so, this is a known issue for Android remotes:
Samsung c Android 12 version 4.1 works fine with New verson 1160 but Huawei tablet started to work even worse. Every time it freezes when viewing a musician’s discography. If earlier I reinstalled the application for fix it, now it’s enough to restart the tablet. If Wikipedia turned off, the application works fine.
There seems to be a crashing issue with latest build and seems to affect iOS user’s as well. A couple of threads are running about it
