MacOS - 2019 MacBook Air - Latest RoonBuild
Connected via USB. Its infuriating!
Hello @DelPrado,
Are you able to play to the “System Output” zone reliably? Try
A. Playing to the system output zone with your MacBook Air speakers as the selected audio output in the menu bar.
B. Playing to the system output zone with the Benchmark DAC2 as your selected audio output in the menu bar.
C. Rebooting your MacBook Air to see if that changes the behavior you are seeing.
-John
