Evgeny
(Евгений Морозов)
1
Tell me the Roon settings for the best sound quality in Holo Audio May. I listen to the Tidal streaming service.
Here are my settings. What else do I need to change?
wizardofoz
(Mr Fix It aka The Wiz)
2
If these are not the default settings then I suggest you reset to default and start there
