Hello,
Is it better to connect the Naim NDX2 streamer directly to the Roon Nucleus via USB?
Or is it better to have both the NDX2 and Nucleus connected to the same network switch via ethernet, as shown in the quick setup guide?
Hello,
Neither is better or worse. You should do whatever works best for you.
Why do people use a streamer with a Nucleus? (Serious question)
I use it for multi-zone around the house with various Roon-ready brands, and not just Naim.
The SQ is better with the Roon Nucleus, as I canât (yet) run an ethernet cable to the streamer or other wireless speakers in different zones.
Iâm trying to determine where to place the Nucleus when I do get an ethernet cable run over to that NDX2 streamer since itâs the digital source on my main system.
If it makes no SQ difference to have it directly connected to the NDX2 via USB, Iâll keep it near the router and switch.
Thereâs no headphone jack? But I donât see why you canât plug your mojo into it.
Roon recommend separating core and renderer, Iâm not sure if this is still the case, but itâs good practice for grouping zones if nothing else. Ethernet gets all the Roon Ready goodness, otherwise, itâs just a USB sound device. As others have said, try it, and stick with what works/sounds best.
The NDX2 doesnât work as a usb DAC. Although it has usb ports, these only work for external usb drives.
Iâd also suggest a temporary hard wire before committing to running a permanent connection - you might find it makes little or no difference.
I ended up separating Roon server and renderer for similar reasons. My server/core is on a fanless NUC (Corei7), while the renderer / endpoint is a Grimm MU1. Ethernet was/is the preferred connection (also as recommended by Grimm). The separation of duties ensures everything runs smoothly (even with my very large library). I tried (briefly) to run both functions from the Grimm MU1, but it choked on the library size. After Grimm support assured me there would be zero sonic cost to splitting the tasks across NUC and Grimm MU1, I have been trouble-free ever since.
Maybe I donât know what a streamer is or does. I use a RPi4 and headphone DAC/amp with my Nucleus.
I used to think the same thing Jim.
But listen to something like a Linn Organik streamer, and youâll âfindâ the answer!
Thanks, but I would never spend that kind of money on this hobby. So, itâs more about the DAC than the streamer, I guess.
There are certain developments that enable us to âtranscendâ this pastime from being a mere âhobbyâ, to that of a pure music lover.
Chordâs WTA filter, as realised in the M Scaler is one of those developments. IMO, Linn Organik is another âgame changerâ.
To me, listening to music isnât a âhobbyâ anymore. Itâs purely transcendental. Thanks to Linnâs âOrganikâ DAC.
Semantics. I would never spend that kind of money regardless of what you call it.
It seems to me youâre not actually listening to music anymore, but rather to your system. Using expensive, âhigh-endâ gear is what actually brings you pleasure. If you need âgame changersâ to keep this going, youâre in trouble. And Iâm off topic.
I couldnât agree more. That âcertain developmentâ is, in my experience, alcohol.
Quite the opposite, actually. And itâs not about things being expensive, or not. Things like Rob Wattsâ DACs, and the Linn Organik DAC just âget out of the wayâ, to allow you better access to the music itself.
You donât listen to the gear. You immerse yourself in the music.
This topic was automatically closed after 45 days. New replies are no longer allowed.
