Model: NUC11PAHi5
CPU: i5-1135G7 Processor (8M Cache, up to 4.20 GHz)
RAM: 16GB
OS: Ubuntu 20.04 LTS
network: Ethernet(1000BASE-T)
Roon bridge: ZEN Stream
Accuphase: DP-410(USB input)
Above device accept 19kHz/24bit.
about 10,000 tracks
I use the DSP Equalizer and Headroom adjustment of Roon. My question is why the bit depth is converted to 16bit, though the original source 192kHz/24bit. The example of signal path is attached below.
Is it because the DP-410 is not identified by Roon?
The detailed settings of Roon are as follows. Volume control is set to Device volume. Max sample rate(PCM) of Audio device is set to Up to 192Hz, but set maximum bit depth is not specified because the corresponding menu was not found.
