Wifi and Ethernet combo
Bluesound Surround Sound (5.1) System. This includes a Soundbar 2i (l/c/r) and a Flex 2 (rear) and a Flex 2i (rear) a wired sub is also attached to the Soundbar.
I can play multichannel music in the native BluOS software; however, when I try in Roon it down mixes to 2 ch. How do I setup the 5.1 to work with roon?
I’ve had poor luck in getting 5.1 tracks played through any system within Roon except AV receivers, I was hoping someone else might be able to @support.
This also applies to B&W Formation 5.1 configuration and Linn Surround configuration. They are seen as stereo endpoints regardless of their configuration.
One way of getting surround sound would be using the HDMI output of a Roon Nucleus/core as an endpoint into the Bluesound Soundbar 2i and let the Bluesound distribute it internally.
