Now that the ultraRendu is out I am considering jumping up from the microRendu. Then it occurred to me that I might add a Bridge 2 to my DS Dac rather than go the Rendu route. I am only concerned about SQ using Roon or Roon/HQPlayer.
Thanks.
One thing to consider is Bridge is limited to DSD64 if that matters to you.
Yes, it does. And, I had discovered that yesterday. I listened to a DS with a Bridge 2 driven by ROCK today. Sounded fine, but I would have put my microRendu ahead in musicality. But, different system different everything, so who can tell.
But the DSD64 limit on the DS DAC which already is limited to 128 marks the Bridge 2 as too limited for me.
Thanks.
