Build 521 - Issue Samsung Tablet with Android 9
Hello,
I have the same issue. Core is running ROCK 1.7 build 521 on a NUC7i7.
My Samsung Tablet with android 9 and my windows 10 remote works fine with build 521.
My Farephone 2 with android 7.1.2 freeze after logging into core.
Hi @Matthias_Kemena,
Is there any change after a reboot? I’ve also enabled diagnostics on the device — Can you reboot and try connecting once more and then the report should be uploaded after that.
Hi Dylan,
thank you for your support. I like roon very much :slightly_smiling_face:
At 8:25 am (Central European Time, CET) i did a reboot of the core.
At 8:27 am (CET) i try a connect to the core with my fairphone remote.
the same behavior was shown. There are no changes after the reboot.
Win 10 remote and Android 9 remote are still okay
Thanks, @Matthias_Kemena. I can confirm that the report has been received and I’ve passed it along to the team for analysis. I’ll be sure to reach out as soon as I have their feedback.
Thank you Dylan,
i am sure that the team will solve the problem
3 posts were split to a new topic: Android 9 Samsung tablet freezing
Hello,
We’ve released a new update, Roon 1.7 Build 528, which contains improvements that we believe will help with the issues you are experiencing here. Please see our release notes below:
Thanks,
The Team At Roon Labs
