Installed Nucleus + . After resolving some network issue (still have no idea what it was, but connected Nucleus+ to different switch/node on my ethernet network), Roon software isn’t finding my PS Audio DSD (with bridge II). Mconnect can find and play Qobuz to the PS Audio and it worked with Roon for the past couple of years as Roon Ready. (It has Sunlight installed). They are on the same wired network (192.168.1.x) Other networked devices (a Marantz receiver and an Integra receiver) are found. Is there any way to force it to find the correct IP address?
