Nicecast is limited to a max mp3 sample rate of 320kbps. Enough for Spotify at the moment but not if Spotify goes lossless or if you want to stream unfolded MQA from the TIDAL app into Roon (Roon currently does not support MQA unfolding).
I would like the ability to stream flac into Roon - although I’m ok with wav or alac. But I am not aware of a solution like Nicecast to do lossless streaming.
I ended buying Nicecast. I prefer it because it means I can run it from a Mac with no impact on my Windows based server machines. Also because Chris from Nicecast came back to me very quickly on my request to add support for other formats such as lossy flac. From his reply it sounded like they’re quite prepared to do that.
Then we would just need Roon to implement .flac for Internet Radio stations, both for the growing number of flac based stations themselves and for support of lossy streaming services such as Qobuz and, hopefully soon, Spotify.
No it won’t provide the wonderful full integration we enjoy with Roon/Tidal; but it would be great to stream Qobuz and any lossless streaming service that may appear in the future through Roon.
I would think so since it requires the BBC player app running in the browser - which has been limited to the UK.
However, the tide is coming. For one, TIDAL is flac streaming, so this exists in some shape or form in Roon. Secondly, I will purchase Nicecast when it and Roon support flac streaming. Not before.
Please send this request to Rogue Amoeba. Just one little guy like me asking for it, won’t do much; but the more that knock on their door with the same suggestion, the better.
[quote]"Would love for Nicecast to stream a lossless FLAC stream. Any way to do this with you other current tools?
I have been an Airfoil customer for a very long time (purchased pretty much all versions) as well as an Audio Hijack and Fission customer (more recent).
I will purchase Nicecast when it supports lossless streaming.
Perfect! This is just what I wanted. Using Stream What You Hear, and adding the mp3 streaming as a radio station. This lets me run spotify on the PC when I am working, and play through Roon Rock on my preferred audio setup. I don’t care about library integration, or hi-res on these streams. Spotify remains the best method to discover new music. Anything that makes the must buy list and can be found in a decent format can then be added to the Roon library
I am using Stream What You Hear to cast to Roon and have a problem:
SWYH on Nuc running Win 10 - headless. When I log in via Remotedesktop, the Stream works to Roon, but as soon as I close Remotedesktop, the Streaming stops, even though the music on the Nuc ist still running.
Obviously I want to have it running constantly on the Nuc without logging in etc. Using SWYH with Spotify Connect and Airplay Server.
Any ideas? Is there a programme that will constantly stream a virtual internet radio to Roon?
Thanks, I tried that. The music keeps playing on the Remote Nuc, can hear it through headphones. But as soon as I stop Remote Desktop the audio streaming to Roon stops.
Prior to SWYH, I have been listening to Tidal through Roon (core on Win 10 desktop) primarily on LS50W or on B&W P7W through Pixel 3.
Using SWYH, I first connected directly to the LS50W from SiriusXM using the “Stream To” menu item where the KEF LS50 wireless was detected automatically.
Later, using SWYH, I was able to connect SiriusXM to the LS50W through Roon as you described. I chose 48kHz 16 bit Stereo format and 320 kbps MP3 bit rate in Settings. Interestingly, in Roon, the source was showing as MP3 48kHz 24 bit 2ch at 320 kbps and 192kHz 24 bit at the LS50W.
On the direct connection, I only listened for maybe a minute, thinking the quality wasn’t that great. I thought the connection through Roon was better, but I would need to listen more to be sure.
If I listen to SiriusXM using the SiriusXM App in Pixel 3 and the B&W P7W I think the quality is still a little better for SiriusXM, but the LS50W are new and not in a good room placement yet.
