Thank you very much for this information.
I dug deeply in the network part and I found in debug mode some trace about a refresh related to IPv6.
The timestamp seemed to match with the Roon network reachability issues. So I decided to disable IPv6.
And so far itās much better. I could use the application without a problem for 5 minutes in a row.
Thing I couldnāt do before.
So I will see, but I think I found the root cause.
The next step for me is to see if it was a normal IPv6 behavior which wasnāt handled correctly by Roon or this behavior is abnormal.
One last thing, may I suggest to change the Network reachability trace by something more relevant like network configuration changed.
Thanks for the update here, glad to hear that disabling IPv6 has helped with the issue! Please, do let us know if the system remains stable or if you run into any other issues.
I can confirm now itās still stable. No issue at all.
Iām wondering if I should close this topic because I donāt know if itās Roon Core issue or a router issue.
Note I have IPv6 enabled for a long time now and Roon is the only application impacted.
