UniFi Dream Machine Pro SE with UniFi Access UAP-AC Pro
2 Raspberry Pi RAAT to S/P-Dif
72.000
I noticed in b-884 the clicking area of the assigned tags is not correct on my iPad. In this example a click on Genre: Gothic leads to the list of tracks with Genre: Post-punk etc.
When playing Roon Radio I sometimes want to assign tags to the playing track.
But when I have already added that album via Tidal in the past that the album shows as not in my library. I checked if there are probably more versions, but that is not the case.
Re-opening that album shows it as added. See the two examples below.
We’re sorry to see that you’re having a few issues and apologize for the delay in getting back to you.
Issue 1:
When you try to click the tag link on a different remote or on your Core do you still have this problem? Could it be that Post Punk is accidentally be clicked on the iPad by mistake due to their being several tags applied to that track selection?
Issue 2:
Can you tell us a bit more about the sequence of events that precede what you’re seeing here Paul?
I click on the album as you can see in the video and it looks like it is not my library (track 7 has been played 17 times).
I add it to my library and nothing happens. I Need to stop Roon twice, because my iPad is not recognised as endpoint the first time and then the album shows as adopted in my library as it should.
I don’t know why or by whom but your last post in this topic has been marked as the solution, and then after a period of inactivity the system automatically closed the topic.
Also on my mobile devices like iPad and iPhone. Even with 2 tags, see screenshot I don’t get the right tag-list. Clicking on the beginning (OCC) of the second tag (Occassion: Party) leads to tag Occassion: Friends.
Can you try something for me? Please try the tag links again for the track you posted above: Born Slippy to see if they still open the incorrect link page.
Then remove the tags, and reapply them. After doing so click the newly applied tags and see if the corresponding tags page is launched.
Thank you for testing it @Paulb! I appreciate your effort and the update. I’m checking with the team to see if there’s anything they can recommend. I’ll be back in touch.
A fix for the tags issue you reported was included in our latest build. Can you install the latest build on all your devices and see if your issue is resolved, please? There could be a slight delay in the availability of the remote app in Apple store.
