Is there a way for me to run diagnostics on my 192khz files that stutter, skip, then go to next track?
Bill_Janssen
(back to Crocs on my asymmetrical isolation feet!)
23
Why not file a support request in the Support category? Fill in the form, and see what Roon professionals have to say.
Otherwise, you could simply downsample the 192 kHz files to something reasonable, like 48 kHz. See if that helps. Odds are this is an issue with either your DAC or your Core computer.
Interesting, because if itâs always the same file, this hints that it has nothing to do with the network. The data amount is the same for all 192/24 files.
If you upload an example somewhere, Iâll try if it plays fine here.
I know that you previously had issues with some 192/24 streams from Qobuz to a Blusound Node. Are you still using that Node?
I put the node in another room, second stereo set up. Itâs replaced it in main room with Cambridge MXN10. I think you said before you could play the tracks I could not. The ones in particular are Zappas Shut up and play your guitar album and Dylanâs first album. There are many others but thatâs a couple
The Cambridge does the same thing as the Node
With the old Qobuz Zappa issue, that was the case. But on Qobuz we canât be entirely sure they served the exact same files to me any you, maybe they came from different datacenters or whatever.
If you now have the issue with actual files on your disc, we could make sure we play the same ones
Aha! Oh well OK, I thought local files now. Sorry, then I have even less idea than back then because you have ruled out the Node now. Very odd, but sorry
So, I just connected my External Hard drive with my cd collection on it. I do have the Zappa disc I am talking about on it. But itâs not hi rez so I guess we canât test anything right?
You can try if that plays for you, but it would be more than odd if that one didnât play for you either. The files should be very different. In that case I would start to believe in Zappaâs ghost haunting you
Yea, all Zappa stuff from Qobuz plays easily when not in 192khz, so guessing my local file will also. Do these local files show up mixed in with the Qobuz stuff? Roon is still adding the files now so canât tell
