In searching I can see that dozens have had this issue but no solution jumps out. When using Roon Nucleus and Tidal, I get error message saying “too many failures” Does not happen on my Muso or iphone. Have tried all the suggested re-logins etc. And, no, my credit card has not expired.
Does this issue happen for multiple audio zones or just one in particular? Is the Nucleus connected directly to the router?
NetGear 90 modem connected to Spectrum cable
Nucleus hardwired to modem
Zone 1; Naim Muso2 - also hardwired to modem
Tidal works fine using the Naim software directly
“too many failures” if I run it from Roon
Zone 2: KEF 50 Wireless -connected via wireless home network (not hardwired)
Roon works fine for stored albums, internet radio etc
Solved it! Not a Roon issue but a Tidal. Even though I changed my email years ago and have been paying under the new account, Tidal still thinks of me in terms of the prior email. When I logged in using that within Roon - problem solved!
