PC.
Aurelic G2.1
I’m having serious connection problems using Roon from my PC to my Aurelic G2.1 player.
It will play a tune and 9 times out of ten it will cut of half way through the song and skip to the next song ans so on.
I have good internet and everything else is ok, Tidal conect Spotify etc.
Can someone help us out?
Providing no details in the text of the post is not going to help anyone to assist you, might I suggest you fill in the pro forma
noris
5
Hi @Philip_Towell,
Is it just the Auralic that is impacted here, does System Output on the PC work without issue (outputting to the PC’s internal speakers)?
Can you please provide some more details on your network? Are both the Core and the Aurelic connected directly to the router?
What is the model/manufacturer of all your networking gear?
system
(system)
Closed
7
