Hi. I have a dragonfly red v1.0, and I cannot figure out how to get a bitperfect stream (without exclusive mode enabled). I thought under the device’s volume control i would have an option for hardware volume, but all i see is DSP, Fixed and CoreAudio Mixer (which I believe is OSX’s internal mixer?).
Once I enable exclusive mode I got a purple icon in roon, and Volume Controls then defaults to “Use Device Controls”, with the last step in the signal path being “CoreAudio Exclusive Mode”. But I don’t believe this is the “cleanest” way of harnessing the dragonfly. Should there not be an option for Hardware Volume Control for the dragonfly without exclusive mode enabled?
I have Dragonfly red as well.
The exclusive mode the way to do it, as it doesn’t allow the interference.
Also, I would suggest you install the Audioquest desktop app and upgrade the firmware on the Dragonfly.
Do you have the DragonFly directly connected to your Mac? That’s not the way I normally use either of my DragonFly’s, but I plugged my DragonFly Black directly into my iMac, and with exclusive mode enabled, I could get a bitperfect signal path if, in the General tab of Device Setup, I set the Volume Control Mode to “Use Device Controls”. Somewhat counterintuitively, this control mode will let you control the volume from Roon or a Roon remote while maintaining “bitperfectness.”
CAUTION: The DragonFly Black had a ton of gain with the settings above, and the Red should have even more, so be careful!
Thanks everyone! Yes, I had already updated the Dragonfly’s firmware. And I saw that the path was producing bitperfect-ness in exclusive mode, but I guess seeing CoreAudio at the end of the path made me question whether I was getting a pure interpretation of the dragonfly’s dac, versus something colored by OSX. But I guess CoreAudio is sort of a neutral API for 3rd party audio protocols, so it’s probably not coloring anything.
I was also expecting that if I was using the dragonfly’s hardware volume, they would be controlled using my macbook, rather than the slider within Roon. So that threw me off.
Yes, there was definitely a good amount of gain when exclusive mode was enabled, which was great because it was needed.
Thanks all for helping me out on this. If my understanding of things seems a bit rudimentary, it’s probably because it is!
I also see CoreAudio exclusive mode at the end of my stream also and only a BLUE LED light on the DFR yet when I use my TIDAL desktop app I have a Magenta LED when listening to TIDAL Masters/MQA.
Why is that? I do have Exclusive Mode and Integer Mode enabled and I am seeing all green lights up to 96kHz in bit perfect format as it should be at the top the page- so why am I only getting 48kHz on the DFR when listening on ROON and not 96kHz?
bobbmd
